Home > Technical (L405) > ECO mode not working on SC
United Kingdom 2017 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
So just driving in my wife new SC and whenever we come to a stop the engine doesn't turn off as I thought it was supposed to in ECO mode.
It's definitely on as if flags when off in the dashboard display so are we doing something wrong?
I've read the manual to see if there is some mode to turn it off permanently but I don't think there is and if there was I guess the orange light shouldn't show next to it.
Thanks
Post #379187 24th Mar 2016 11:14am
Charlyfarly
United Kingdom 2015 Range Rover Autobiography SDV8 Santorini Black
Found this on another site (yes, I'm a slut and being unfaithful):
Things that prevent an automatic engine stop include:
◦An automatic transmission shift paddle has been used to select a gear.
Heated front or rear screen on.
◦The external temperature is less than approximately 0°C (32°F).
◦The external temperature is more than approximately 40°C (104°F).
◦The engine has not reached operating temperature.
◦The driver’s seat belt is not fastened.
◦The climate control system demand requires the engine to be running (for example, in Defrost mode).
◦The battery charge is low.
◦The bonnet is opened.
◦Intelligent stop/start is deactivated.
Tony
Post #379190 24th Mar 2016 11:51am
Interesting thanks, only think I can possibly think therefore is battery low as its been sat around a few weeks.
Everything else is turned off or n/a in that list.
Post #379193 24th Mar 2016 12:00pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
ECO mode on a SC Chocolate teapot ? Glass hammer ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #379215 24th Mar 2016 12:50pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
The stop/start will not function unless the brake pedal is firmly pressed at standstill. You can fool the car to not shutdown, or vice verse, by being gentle on the pedal.
There was a software update for the stop/start that cured a bug that might not restart the engine. (you evidently do not have that problem).
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #379263 24th Mar 2016 9:19pm
It's still under warranty so I'll pop it back to a dealer to have a look.
One other random question, is the lower tailgate powered open and close or just power close.
I think ours is sticking as when you press the button to open the lower tailgate it moves a tiny bit and that is it, bust then I wondered if it's just a gravity/manual open?
Post #379296 25th Mar 2016 6:03am
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
It should power open and close. My stop start Eco thingy seems sensitive to whether the air con is switched on or not. If I stop at a junction then sometimes the engine will continue running but if I switch the air con off then the engine will stop. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #379298 25th Mar 2016 6:35am
All sounds low battery voltage related to me. Power boots on most cars are the first to suffer I have found so maybe ask them to check battery health as well while its in, or if it's not getting used enough drop it off with me for a few weeks Wink FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #379337 25th Mar 2016 10:42am
Think you might be right, the ECO system did start working today so I wonder if the car has been sat for a while and hence the battery is low. Anyone have any idea of how quickly a battery gets to full charge if it's low normally?
We drove for around 2.5 hours after picking up the car so if it takes much longer that might explain why the ECO only started working earlier today, equally the battery might be duff. I'll look at charging it, assume I just to it via the jump points?
Post #379409 25th Mar 2016 9:31pm
To be honest hat can work but charging via the trailer socket is the easiest charging method.
It shouldn't take more than 30mins to fully charge a nearly depleted battery but on yours I believe it's an agm type so won't be cheap to replace. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #379410 25th Mar 2016 9:35pm
Charlyfarly
CTEK MXS 5.0 is the way to go.
Excellent charger. If it ain't broken, fix it till it is.
Post #379411 25th Mar 2016 9:37pm
As it happens that is the charger I have. I've put it on charge over night. If that doesn't show good improvement I'll use the AGM reconditioning mode.
Post #379443 26th Mar 2016 6:00am
Fully charged but ECO not working! Think this might be a dealer fix then.
Post #379518 26th Mar 2016 4:34pm
