![]() | Home > Technical (L405) > ECO mode not working on SC |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Found this on another site (yes, I'm a slut and being unfaithful):
Scotland Member Since: 29 Feb 2016 Location: Worcestershire Posts: 81 ![]() ![]() ![]() |
Interesting thanks, only think I can possibly think therefore is battery low as its been sat around a few weeks.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
ECO mode on a SC Chocolate teapot ? Glass hammer ? 2015 4.4 AB
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
The stop/start will not function unless the brake pedal is firmly pressed at standstill. You can fool the car to not shutdown, or vice verse, by being gentle on the pedal.
It's still under warranty so I'll pop it back to a dealer to have a look.
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
It should power open and close. My stop start Eco thingy seems sensitive to whether the air con is switched on or not. If I stop at a junction then sometimes the engine will continue running but if I switch the air con off then the engine will stop. Agueroooooooooo. 93-20
All sounds low battery voltage related to me. Power boots on most cars are the first to suffer I have found so maybe ask them to check battery health as well while its in, or if it's not getting used enough drop it off with me for a few weeks |
Think you might be right, the ECO system did start working today so I wonder if the car has been sat for a while and hence the battery is low. Anyone have any idea of how quickly a battery gets to full charge if it's low normally?
To be honest hat can work but charging via the trailer socket is the easiest charging method.
CTEK MXS 5.0 is the way to go.
As it happens that is the charger I have. I've put it on charge over night. If that doesn't show good improvement I'll use the AGM reconditioning mode. |
Fully charged but ECO not working! Think this might be a dealer fix then. |
