![]() | Home > Technical (L322) > Flashing sidelights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
if you have leds in them ,then they will do that Chef.. ... - .- -.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
You're just wasted here!
They do it because the LCM sends a small voltage to check the bulbs working... The voltage would not be enough to light an incandescent bulb BUT is enough to make an LED flash... It then checks a couple more times in short sucsession as it see’s a fault in the system (the LED’s) |
All makes sense to me now! Thanks Stan and Cam tech!
Craig will do chief |
Craig it is then |
