Home > Technical (L322) > Flashing sidelights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35280 |
if you have leds in them ,then they will do that Chef.. ... - .- -.
24th Mar 2016 10:26pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 745 |
You're just wasted here!
24th Mar 2016 10:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
They do it because the LCM sends a small voltage to check the bulbs working... The voltage would not be enough to light an incandescent bulb BUT is enough to make an LED flash... It then checks a couple more times in short sucsession as it see’s a fault in the system (the LED’s) |
24th Mar 2016 11:09pm |
All makes sense to me now! Thanks Stan and Cam tech!
24th Mar 2016 11:12pm |
Craig will do chief |
24th Mar 2016 11:58pm |
Craig it is then 2014 vogue se |
25th Mar 2016 9:20am |
25th Mar 2016 9:46am |
