![]() | Home > My Range Rover > Another Garage Visit, this time it will be staying there. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
sounds like your window trims, were just minor detail. they all go rotten in the end, mine were. The DPF was maybe an oversight from a service, or previous owner meddling. The strut sensor, might just be 'one of those things' cant comment on that, but the inlet manifold, surely thats covered on the warranty, and injectors changed, that sounds like garbage, but i dont know your model. the worst bit being the 2600 euros, on you bill. i understand your frustrations, but that surely needs more conversation, as the manifold doesnt just break....i know many are plastic thesedays, but how could it be not warrantied? |
fatbob Member Since: 16 Aug 2015 Location: Munich Posts: 19 ![]() ![]() ![]() |
@johnboyairey
replace fuel lines and injectors...... because they are all faulty, or its all 'one unit' from the factory?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
John I think his is the TDV8 4.4..... |
Hi,
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Apart from the manifold, these are minor issues that seem to have been escalated for you by an inept dealer. I had a similar experience here in the UK when I bought our last fatty, although that was 9 years ago. It took the idiot dealer nearly 12 months to sort out the delivery issues (mostly minor) and they never did get the aircon to work properly (I did, it was the hedgehog resistor!). Everything worked out fine in the end when I started taking the car to my local indie and it's been pretty reliable now for 8 years and 50k miles in our ownership (done 93k total). It's still a lovely car. Drives:
I really wish I had an indy here, but living in Germany I dont actually know of an LR specialists in the area (What a difference from the UK where I had 4 within a 20mile radius)
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Could this be a case of an inept German dealership? The FF is not common in Germany so i guess the dealers are NOT very knowledgable???
I have every sympathy with you fatbob and would almost certainly feel the same in the same circumstances. There is no reason why the dealer couldn't have fixed the minor faults at the first attempt and the manifold should definitely be a warranty item. In my experience with anything slightly obscure (which this is) the first port of call is to claim it isn't covered. Check the terms and conditions of your warranty. If it transpires that they have managed to exclude it, then at that age L-R should make a very significant contribution to the repair. They are marketing what they want us to believe is a premium product and that requires a premium service. Too many manufacturers try this on, and all they are doing is charging a premium price for a mass market service and customers won't be fooled forever. Drives:
