Home > Technical (L322) > Rear bushes? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
this will help,
21st Mar 2016 10:26am |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
Thanks for the link , have had a read and i guess its the rear track control arms i need ? |
21st Mar 2016 10:33am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8282 |
The only arms on the rear are the toe control arms, I think you will find they are OK, it is usually the upper and lower hub bushes as in Stan's link... Pete
21st Mar 2016 11:10am |
Ordered upper and lower bushes and arms for both sides, so hopefully that should cover it, thanks for the help all. |
21st Mar 2016 1:19pm |
Are you fitting them yourself...?? Pete
21st Mar 2016 5:11pm |
No my local indy is fitting it all, then fitting my new tyres and then doing the 4 wheel alignment/tracking
21st Mar 2016 5:45pm |
I'd order new bolts, washers and nuts for the rear hub bushes, the old ones will be very rusty and very tight, I snapped one of mine getting them out, they have a cam washer arrangement for camber adjustment so you can't just use any old bolt, got mine from Dan at Duckworths, not that much money... Pete
21st Mar 2016 6:35pm |
Thanks for the advice I will pm Dan now and get them ordered |
21st Mar 2016 8:02pm |
