Home > In Car Electronics (L322) > Satnav lost the plot |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
have a look behind the speaker panel and see if there are any lose cables or plugs detached, other wise try a battery disconnection.. ... - .- -.
16th Mar 2016 3:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
There is something about this somewhere, something to do with the gps antenna in the shark fin as far as I can recall there can be water ingress and it can fail.
16th Mar 2016 7:08pm |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 |
I had the same with mine I changed the sharks fin and all is jolly again . Do you have the GPS signal icon in the top left corner on the map screen? |
16th Mar 2016 7:38pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
well in the true range rover manner it's fixed itself and giving me more info than before it now tell me about roadworks ahead L322 2008 vogue
17th Mar 2016 2:49pm |
NMJ might be correct in his assumption, its dry and sunny now so your nav is working ok, i bet the next time it rains you'll have problems... ... - .- -.
17th Mar 2016 3:20pm |
Yeah i know what your saying that was my first thought as well L322 2008 vogue
17th Mar 2016 3:33pm |
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 |
Ditto. Mine was cracked. When the sun shone it worked. When it rained it didn't. Easy enough to fix and takes about 30-40 minutes. |
17th Mar 2016 4:53pm |
