Home > Technical (L322) > Steering reach not working |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
http://www.fullfatrr.com/forum/topic34124.html
13th Mar 2016 10:32pm |
Madmutt0 Member Since: 18 Feb 2016 Location: Bristol Posts: 78 |
Hi think the plastic bracket has broken can this be replaced without too much trouble thanks |
14th Mar 2016 10:06am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
You need to get in touch with Uli, member on here , username meerbush, he sells the fix on eBay + a full write up on here somewhere |
14th Mar 2016 11:31am |
See the link I posted above |
14th Mar 2016 1:40pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
It works very well.
14th Mar 2016 2:28pm |
Thanks will look at the week end to see if it is the bracket or the little block my steering wheel has no play at all if I try to move it by hand |
14th Mar 2016 2:51pm |
Hi can anyone give me some advice please I've took off the steering cover and yes part of the bracket fell out
15th Mar 2016 11:34am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
You can replace the bracket fairly easily, have you found the small narrow drive shaft?- if its it not there its usually fallen down the back of the footwell either in the lower dash tray or mine was sitting on top of the trim behind the pedals. It will be there somewhere!
15th Mar 2016 12:50pm |
Hi nick yes little flex was still in place is it easy to fit back together I'll let you know how I get on thanks again bob |
15th Mar 2016 1:11pm |
Hi nick how should I put the cable back is the a order thanks bob |
15th Mar 2016 1:53pm |
Hi Bob
15th Mar 2016 2:25pm |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 |
I'd suppose that it would make sense for those of us that did not yet have any issues with the mechanism to go to the bother of removing the bottom steering cover and greasing anything that moves. |
15th Mar 2016 4:28pm |
Well that didn't take long. I decided to go do it instead of talking about it. All greased up now, 15 minutes work. |
Ordered new bracket and cheapest I could get was main dealer at 32 pounds even cheaper than parts dealers |
16th Mar 2016 9:18am |
