![]() | Home > Technical (L322) > Fault code reader recommendation advice please |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I use one of these- |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Thanks for that, I shall be ordering one tomorrow. |
I use one of these (or very similar to):
The EAS Activate is a must have gadget too:
hi dan, trims on the way...back to the fault software, most code readers willonly read/clear engine faults, what does yours cover
Mine will read all available OBD info which is limited to the engine ECU so no other systems like EAS, ABS etc.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
I got the elm one and digimoto but cant seem to get live data.
VW cars need Vag-Com protocol: http://shop.ebay.co.uk/?_from=R40&_trk...Categories Similar, but not interchangeable. |
thanks mate... ![]() |
Now i know you have digimoto running live date on a FFRR ill have to have another play.,, |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
What year is the Golf? I'm sure mk5 onwards aren't compatible with VAG-COM, well that's what I was told about my parents mk5 Golf 2006 Mercedes CLS
Yes a MK5
Sometimes you've got to change the interface type - in the bottom right of my screenshot where it says ELM323 if it says something different on mine it doesnt work propperly... ![]() |
I now have the ELM 327 interface, which works fine with the basic software that comes with it but I cant get it to work with Digimoto V4.03.
