![]() | Home > Technical (L405) > Exhaust filter nearly full |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Hi all,
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1105 ![]() ![]() |
JKay that is one of the best forum answers I have ever read, Charley you clearly are not using the car enough or enjoying it enough, please give it to someone who will. letters not necessarily in the right order |
Jkay Member Since: 12 Apr 2015 Location: Sydney, NSW Posts: 208 ![]() ![]() |
Cheers Dixy! |
And do it soon if it get too clogged you will not be able to regen meaning a new CAT...... |
Thanks JKay (in particular) and Dixey.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
If you have used the car recently, i would run the car into your dealer sir as clearly something is filling your DPF up! There is a well known issue with a temp probe in the NS manifold that fails making the car over fuel... This does NOT bring up an EM light but will give sporadic "engine fault messages� |
Thanks Craig.
I wonder how effective this stuff would be? Or whether it's better just to go for a blast
