Home > Technical (L322) > rear heater
mark g
United Kingdom 2004 Range Rover Vogue Td6 Java Black
rear heater
my rear heater is only giving out hot air , the front seems to be fine and the fan speed control seems to work fine i just cant vary the temp at all , could it be the switch or the blend motor? thanks for any help, mark.
Post #376385 8th Mar 2016 4:24pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
mines doing the opposite can only get cold.
Post #376388 8th Mar 2016 5:08pm
I quote,
"On high line heater assemblies, a blend flap is installed for the rear passenger face level outlet to allow the
temperature of rear face level air to be adjusted independently from the temperatures selected on the control panel.
The blend flap is driven by a stepper motor controlled by a thumbwheel on the rear passenger face vent. The blend
flap is also used to close off the rear face level outlet when maximum air output is required for the front outlets, e.g.
when defrost is selected."
Post #376397 8th Mar 2016 6:08pm
mark g
yes i saw but didnt want to clutter up your thread,
if you have a read of this you might understand it a bit better i think my heat control switch has failed but was hoping someone may confirm my diagnoses, http://workshop-manuals.com/landrover/l322...ntilation/
cheers, mark.
Post #376422 8th Mar 2016 7:45pm
lighthouse
Thanks will take a read, hope we can fix both of our issues.
Post #376429 8th Mar 2016 8:13pm
mark g
after re reading nicedayforits post, i set the rear fan to its highest setting and then turned the front heater to defrost, immediately the rear heater shut down so this indicates the heat control switch to be the problem as the blend flap is working
thanks once again nicedayforit
Post #376598 9th Mar 2016 8:42pm
Post #376611 9th Mar 2016 10:07pm
