Home > Technical (L322) > rear heater |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
mines doing the opposite can only get cold. |
8th Mar 2016 5:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I quote,
8th Mar 2016 6:08pm |
mark g Member Since: 28 Dec 2015 Location: Shropshire Posts: 31 |
yes i saw but didnt want to clutter up your thread, if you have a read of this you might understand it a bit better i think my heat control switch has failed but was hoping someone may confirm my diagnoses, http://workshop-manuals.com/landrover/l322...ntilation/ cheers, mark. |
8th Mar 2016 7:45pm |
Thanks will take a read, hope we can fix both of our issues. |
8th Mar 2016 8:13pm |
after re reading nicedayforits post, i set the rear fan to its highest setting and then turned the front heater to defrost, immediately the rear heater shut down so this indicates the heat control switch to be the problem as the blend flap is working
9th Mar 2016 8:42pm |
9th Mar 2016 10:07pm |
