![]() | Home > Maintenance & Mods (L322) > Which trickle charger |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 ![]() ![]() |
Full fat may very well be sat for weeks at a time,so considering a trickle charger.Anyone recommend some thing reasonably priced?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Can't go wrong with a CTEK |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
I have the same issue.
Cheers chaps ,always reasuring to hear opinions on here |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8355 ![]() ![]() ![]() |
I got a silly cheap one from Lidl or similar a few years ago... about £9.99 if I remember right, it can be hard wired as well...
Also if it's plugged in on the drive, make yourself a big sign saying so and wedge it in the steering wheel or one day you WILL drive off with it still connected.... |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 ![]() ![]() |
Done that! Drove over the Ctek Zafir 100 charger (connected to a water proof socket mounted in the right lower air vent in the grill).... Repaired the cracks in the Ctek with some Tec7 - still working fine ![]() What I do now when connecting the charger, is to pull the 220v cable over the side mirror on the driver side. Then I shouldn't forget that the charger is connected ![]() |
