Home > Maintenance & Mods (L322) > Which trickle charger |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 |
Full fat may very well be sat for weeks at a time,so considering a trickle charger.Anyone recommend some thing reasonably priced?
5th Mar 2016 9:08am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 |
Can't go wrong with a CTEK
5th Mar 2016 9:28am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 |
I have the same issue.
5th Mar 2016 9:37am |
Cheers chaps ,always reasuring to hear opinions on here |
5th Mar 2016 11:32am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8355 |
I got a silly cheap one from Lidl or similar a few years ago... about £9.99 if I remember right, it can be hard wired as well...
5th Mar 2016 12:25pm |
Also if it's plugged in on the drive, make yourself a big sign saying so and wedge it in the steering wheel or one day you WILL drive off with it still connected.... Pete
5th Mar 2016 12:27pm |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 |
Done that! Drove over the Ctek Zafir 100 charger (connected to a water proof socket mounted in the right lower air vent in the grill).... Repaired the cracks in the Ctek with some Tec7 - still working fine What I do now when connecting the charger, is to pull the 220v cable over the side mirror on the driver side. Then I shouldn't forget that the charger is connected |
5th Mar 2016 1:03pm |
