Home > In Car Electronics (L322) > Backlight
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Backlight
Hello team
Two questions, The touchscreen in my 2005 is brighter one side than the other this has only happened recently is there a replaceable lamp in the back of the screen?
Also despite having a new battery at Christmas twice this week the car has been flat when I come to start it (It is used daily) I have put the old battery on and it's gone flat again so it's not the battery. I suspect the FSR althought it appears to work normally and I replaced it a couple of yeras ago when it failed totally but I have seen a lot of threads on the subject.
Any idea's?
ta
Andy Mine was a blue one! Smile
Post #375679 4th Mar 2016 10:42am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi Andy, don't know about touchscreen, could be battery related. Mine dims at night , but that's all over.
sound's like you have a drain somewhere, the usual places to check fsr etc. Sorry not much help but thought I'd bump it for you, maybe someone who's got a better idea will come along. Thumbs Up
Post #376069 7th Mar 2016 6:35am
What battery did you have/replace it with? When was the last time you performed a hard battery reset?
Post #376072 7th Mar 2016 8:39am
Andy3681
Hi Craig
It was a VARTA Silverline 110 AH as was fitted.
It's seems to be starting fine on the old one.
The new one did come up faulty on a CTEK charger but that might be because it was very flat.
However I have had it on charge and it came up over night. However a battery test couple of days later says its only at 80% so not sure??
Did a hard reset while I was changing the battery back. Mine was a blue one! Smile
Post #376088 7th Mar 2016 10:02am
