2010-2012 rear fog 'always on' led light conversion hack | |
this hack is for the 'fog light always on' problem when fitting the new led rear light units on a pre 2010 FF..
the proviso is that you must have tow bar electrics fitted..
cut the Yellow/Black wire to each rear light (fog light)
connect this to the blue wire coming from your trailer electrics (rear fog light feed)
this will stop your rear fog light issues by feeding the rear fog lights a clean on/off feed from the towing ECU
using a diagnostic tool like the GAP iidtool, turn off the hot & cold monitoring on the rear lights
all credit to forum sponsor and 2010-12 conversion specialist , Craig @ cam-tec
http://www.cam-tech-landrover.co.uk/ ... - .- -.
