![]() | Home > Technical (L322) > Final Stage Resistor |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
rear heater is on a seperate FSR so it does sound like it could be the front FSR that is playing up
fogotter Member Since: 01 Mar 2016 Location: hull Posts: 24 ![]() ![]() ![]() |
Hi Nige,
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Hi Paul. As long as you have power to the fuse it's probably your next cheapest option. They are a bit of a |
Brooksy Member Since: 18 Sep 2015 Location: Caister-on-sea Posts: 23 ![]() ![]() ![]() |
had the same problem on my 2002 td6, turned out it was the brushes in the heater motor itself |
Well,
