Home > Technical (L322) > Rest Heating (Residual Heating)
dan_uk_1984
Hi Guys,
I'm wondering whether the rest heating feature was removed from 2005 (55) onwards as it doesn't work in mine... I checked the 2006 owners manual on Topix and it is still listed in the manual, but wouldn't be the first time the manual has been wrong about something.
So does anyone have a 55+ that can confirm whether the Rest Heat function is still there please?
Thanks,
Dan
Post #375397 2nd Mar 2016 8:43pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I don't see a button for it in my 06
Post #375466 3rd Mar 2016 9:36am
Duracell777
Is this not the 'MAX' button Question
Uses residual engine heat to keep cabin warm. Up to 15mins I believe.
I'm sure someone will clarify.
Mines a 2007(57) Vogue 3.6TDV8
Andy.
Post #375527 3rd Mar 2016 11:59am
lighthouse
Might me, my 5 series BMW which is basically the same system had a res button where the heated seat buttons are on the RR.
I will try the max when i go and get the wife at lunch time and provide feedback.
Post #375528 3rd Mar 2016 12:01pm
lighthouse
i can confirm that pressing max after turning off engine and ignition does indeed provide residual heat.
Tried it on mine and works until drivers door is opened.
Post #375558 3rd Mar 2016 3:02pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Same here with the "Max"? button.
Ours is a tdv8 diesel though.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #375602 3rd Mar 2016 7:45pm
dan_uk_1984
Damn. OK thanks guys. I assumed the feature was only on the BMW engine but obviously it just doesn't work on mine.
I wonder what's broken that causes it not to work. I've had the aux coolant pump fail before, the rest heat function still runs, just blows cold air.
Will dig the code reader out tomorrow I think...
Post #375627 3rd Mar 2016 9:13pm
lighthouse
good luck let us know what u find
Post #375629 3rd Mar 2016 9:24pm
