![]() | Home > Maintenance & Mods (L322) > Central locking woirking on one side only |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Have you tried pressing the button again once the drivers side is open? I know volkswagens used to or still do this when one press opens the drivers side and two to open all doors! No idea if this would be the case on yours but may be worth a try as it could be hat simple! Probably not though |
fogotter Member Since: 01 Mar 2016 Location: hull Posts: 24 ![]() ![]() ![]() |
Hi Kbald,
I presume they lock ok? My guess would be Both NS latches will have failed... The central locking motor is held within the latch |
Cheers Craig,
You didn’t answer as to weather they lock or not sir? |
Sorry Craig,
In that case, even more certain now sir... Definitely the door latch assemblies at fault... We do lots of them |
Thanks Craig,
Your welcome sir... |
Well my nearside door catches have arrived and I am poised to take off the door card.
If you disconnect the battery Paul, the airbag system is dead sir...
Cheers Craig,
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I had a similar issue when I installed new door handles. Only certain doors would unlock with others doing nothing.
