Home > Technical (L322) > Unexplained battery discharge????
Page 2 of 3 <123>
Good news, funny how a dying battery can cause so many odd faults. Discovery 4 HSE
Post #3659 10th Mar 2009 11:16pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Low Voltage causes more than a few
Beware of leaving things connected to the aux power in the cargo area as its a perm live Thumbs Up
Post #3667 11th Mar 2009 8:11am
JW911
Thanks for that. I've just taken Jonny's advice and set the steering wheel fully forward and moved the seat so the wheel doesn't motor in and out when I put the key in. My Bluetooth headset and satnav stay plugged in all the time (in the armrest in the centre console) so I'll keep an eye on that.
Post #3753 12th Mar 2009 11:37pm
jediwhite
Ireland 2003 Range Rover Vogue Td6 Java Black
Hi
I'm a new member with a 2002 Vogue and the same battery drain problem. I've tried changing the HEVAC relay as recommended but no change.
Can anyone recommend the best battery to use cos if I change mine I want the best I can get.
Cheers Jed
Post #8473 17th Nov 2009 2:34pm
my local garage fitted a Bull battery, seems ok to me!
Ken knows a lot about batteries.... Discovery 4 HSE
Post #8481 17th Nov 2009 4:41pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
Doesn't just affect the Range Rover - many other brands suffer too when the battery is passed it's best.
Post #8511 18th Nov 2009 11:58pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have had flat battery problems, the first 3 years ago was caused by the relay for the headlamp wipers coming on and allowing the wipers to run the battery down. I wondered why they were parked across the lights at times. New relay cured it.
It happened again on Monday of this week so dumped the car at the dealers, got a phone call to say one of the headlamp wiper motors was taking power all the time, they have removed the fuse.
Picking it up tomorrow so will have to replace motor when the weather improves.
Ian
Post #11094 14th Jan 2010 3:50pm
dan_uk_1984
Ian
If the frost freezes them they can get out of sync and get confused. Although I've not heard of that causing battery drain, wipers pointing to the sky is common in summer.... Pop the fuse back in just to see if they reset.
Dan
Post #11096 14th Jan 2010 5:20pm
The doc
2008 Range Rover Vogue TDV8 Java Black
Good advice RRUK.
Always change your battery at the first sign of any starting problems - there cheap and once you have changed it you know where your at.
Looking around here 90% of flat batterys test fine but there not! Thumbs Up '09 Freelander 2 TD4 HSE Auto for the Mrs
Using the works Fiesta 1.6 TDCI Sport Van - CHROME FREE THOUGH
Searching for a nice E63 AMG or S8 V10 to replace my "wonky" TDV8
Post #11103 14th Jan 2010 6:00pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
i had the dreaded bty problem last summer, i went to kwik fit and some gobby young lad measured the battery and said it was ok
he was talking a load of crap and the battery went from not very good to absolute crap
i changed the HVAC relay and the battery at the same time ive had happy starting ever since
battery on cars do not last for ever typicaly around 5 -7 years or so im told
i also bought the modefied wiring loom for the Hvac but have not had time fit
i believe the once the battery gives up the ghost and starts to play up CHANGE IT Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #11130 15th Jan 2010 11:08pm
IanV8
Put the fuse back in this morning and when I walked round the front the wiper had parked.
Lights on, wash windscreen and both headlamp wipers now working
Guess it was the low temperatures, will have to check they are parked after use in cold weather.
Yoy would think that with all the computing power it could sense something was taking power when it shouldn't and turn it off.
IanV8
Post #11396 22nd Jan 2010 1:34pm
mmuhlen1
Im also currently having this battery drain issue. Replaced battery, still won't start after a 1 day of sitting. Pretty sure the alternator is working fine.
Not sure about the HVAC issue, pulled fuse 64 and still seeing the drain.
I can hear some slight noise buzzing coming from inside around center dash. Pulled fuse 15, or 12 and it seemed to stop. Still waiting on weather thats the issue.
Headlight Wipers might be an issue as they have been stuck for some time. But what fuse number are the headlight wipers on??
Any advice would help. Thanks
2003 Range Rover HSE
Post #13528 21st Feb 2010 10:53pm
andyw
you said you can hear a fan like noise coming from the centre console this could be that the final stage fan is not being told to go to sleep and or waking up intermitantly and draing your battery. the easey way to check is to
switch off remove keys from ignition
lock the car (with you in it)
there is an red led on the centre console near the terain / low gear switches after a s mins that should go out and the fan will stop
if they dont then the car is not going to sleep
the biggest tell tale is the fan will never stop
you need to be patient and stay for around 30 min tosee if the the car wakes up and the fan comes back on
mine took about 15 min to turn on a gain (i looked a little daft sitting still with no engine on or music Rolling with laughter )
if it it does come back on theHVAC is not performing and needs replacing
have fun dont forget the interior alarm sensor
regards
andy 02 Range Rover HSE Zambezie silver 4.4
Post #13535 22nd Feb 2010 12:45am
mmuhlen1
Yes, I hear a slight humming noise from center console. Its very quiet.
However, i did what you said and sure enough locking it and me sitting inside after about 15 min everything went down and then started back up again, like it tried to sleep, but woke back up instantly. The red led by the Park went off then came right back on. So does that mean its the final stage relay? Or what was all fixed with yours? Thanks
Matt
Post #13539 22nd Feb 2010 2:53am
andyw
yep thats what happened with mine and i change the HVAC (bit of a Censored ) to do i also changed the battery and i have had no probs
the HVAV is around 50 quid from a stealer part no. JG0000021 i think it is a triangular shaped with metal rods Thumbs Up
it is way under the drivers side centre console
when i got mine the part bloke said they dont get through many but when he check he had them in stock
if you need a step by step then i can
to be sure
do the same but wait out side the car Weather permiting) and you will see the led come on and you will no for sure that it was not you moving in the cab. also a school of thought is that a HVAC loom using the modified wiring harness YN1500040K can help i got one and did not fit and have had ho probs
for the sake of 50 quid and a new battery it could save a stealer eating your wallet and not solving the problem
regards
Post #13641 22nd Feb 2010 11:39pm
Page 2 of 3 <123>
