![]() | Home > Technical (L322) > Unexplained battery discharge???? |
terex48 Member Since: 06 Feb 2011 Location: Scotland Posts: 8 ![]() ![]() ![]() |
I had a battery drain problem and found out it was the head lamp wiper relay , I pulled the fuse and have not had the problem since , I noticed it first by the wipers , they were not parking properly ( touching the bumper) I adjusted it then it was touching the bumper again . Not changed the relay yet as it is in behind the dashboard . 2004 Range Rover Vogue TD6
If you put the fuse back in they should park propperly, there is no manual adjustment you can do with them, they have to sense that they are "home"
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I'm thinking sensor. 2010 Disco XS TDV6, 2009 Freelander 2 GS Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
Well stealer says they did a software update during the last visit, and a month down the line the discharge hasn't happened again. Touch wood it's fixed.
Jackofq300 Member Since: 11 Aug 2013 Location: Dart ford Posts: 45 ![]() ![]() ![]() |
