Home > Technical (L322) > P0174 |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Anyone know what could be causing P0174 errors to keep coming back, also getting it for bank 1 as well sometimes. Happens on both LPG and petrol so have ruled out the LPG system.
2nd Mar 2016 9:39am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35269 |
done a forum search and that code is mentioned in the following threads,hope it helps,
2nd Mar 2016 9:43am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
lean code , most likely unmetered air entering somewhere , best guess would be at breather hoses on either side of engine , the one on the drivers side can be most problematic IME .( crap design and slack o ring )
2nd Mar 2016 11:09am |
which hoses are you talking about? |
2nd Mar 2016 11:11am |
stand in front of car , remove engine cover , look left at top of engine theres a breather hose that clips into a corrugated type hose listen for it sucking air , theres a smaller breather hose on the other bank check that too.
2nd Mar 2016 11:19am |
can't seem to find any diagram of the engine its not on rave |
2nd Mar 2016 11:22am |
it wont be on RAVE, rave is for 2002-2005....... try the 2006-2009 WM... ... - .- -.
2nd Mar 2016 11:32am |
i Am being stupid. WM? Do you mean workshop manual, I will have to try and find a copy. |
2nd Mar 2016 12:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Here you go, it's in the WIKI...
2nd Mar 2016 12:31pm |
thanks |
2nd Mar 2016 12:41pm |
