![]() | Home > Technical (L322) > P0174 |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Anyone know what could be causing P0174 errors to keep coming back, also getting it for bank 1 as well sometimes. Happens on both LPG and petrol so have ruled out the LPG system.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
done a forum search and that code is mentioned in the following threads,hope it helps,
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
lean code , most likely unmetered air entering somewhere , best guess would be at breather hoses on either side of engine , the one on the drivers side can be most problematic IME .( crap design and slack o ring )
which hoses are you talking about? |
stand in front of car , remove engine cover , look left at top of engine theres a breather hose that clips into a corrugated type hose listen for it sucking air , theres a smaller breather hose on the other bank check that too.
can't seem to find any diagram of the engine its not on rave |
it wont be on RAVE, rave is for 2002-2005....... try the 2006-2009 WM... ... - .- -.
i Am being stupid. WM? Do you mean workshop manual, I will have to try and find a copy. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Here you go, it's in the WIKI...
thanks |
