![]() | Home > Maintenance & Mods (L322) > Thought all the niggles were ironed out. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Did a trip Bristol to Hartlepool and return. All fine, even towed the milkman's Transit out a side road, after he took a wing mirror off a car parked behind me, in the snow yesterday.
No my son will weld it and he wants it off so can get easy access to it. Just got to worry about the manifold bolts coming off. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8354 ![]() ![]() ![]() |
Took mine off last year, I was thinking it would be the usual rusty stud, strip or snap, swear etc etc...
Exhaust all welded, lost that roar and can now not hear the engine at tick over again.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
The often leaking 4.4 engine, has a quality, when the coolant leaks, from the engines' valley pan seal, and deposits into a small area at the top left of the inlet manifold. This has a small hole, that allows build up of coolant, to drain down the back of the engine, and it drips out the bottom of bell housing.
Cheers for that.
Don't forget the gearbox oil is NOT red it's about the colour of clean engine oil.... straw colour... |
Yes aware of the fluid colour.
