Home > Maintenance & Mods (L322) > L322 Update/Upgrade |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Thanks but I don't have a IIDTool. |
1st Mar 2016 8:41pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6703 |
Good reason to buy one then Got - 2017 SDV8 Autobiography in Loire Blue
As does the faultmate and sdd units. But if you want to upgrade it I'd say it's worth doing the 2010 and I've done both so know what I'm on about 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Hi kp, sorry for hijacking the thread, is the d4/rrs module plug and play, cus I have the nokia bt module that can't be updated.
1st Mar 2016 8:57pm |
It isn't what most would call plug and play but if you can cut two wires and strip the plastic back from them then it's easily DIYable. I've done a few members before but with work being as it is at the minute I haven't got much spare time anymore.
1st Mar 2016 9:00pm |
DSCOOPS Member Since: 15 Jul 2015 Location: Staffs Posts: 26 |
EGR'S can be switched off in the ecu. Just had mine done. I think then you can physically blank them but haven't seen any blanking plates for sale. You can get the egr patch for the iid from bas. |
1st Mar 2016 9:33pm |
What does the switching off the EGRs do to the FFRR and why do it?[/s] |
1st Mar 2016 9:37pm |
The switching off stops the egr valves opening preventing exhaust gases being mixed with fresh air back into the engine - this being a method to minimise emissions by reburning exhaust gases. Problem being that exhaust fumes are dirty and clog the valves meaning they get stuck and stay open when they shouldn't. |
1st Mar 2016 9:44pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^^ then they clog up all the inlet side of the engine, and I suspect that they cause the back pressure to climb to a level where the turbo says "sod this I'm off, BANG " That is purely speculation.... but I have heard more than once that turbo failure is due to blocked / malfunctioning EGR valves
1st Mar 2016 11:32pm |
So is it better to leave as is or get them mapped out or removed/blanked? |
2nd Mar 2016 12:51am |
If you get them mapped out, they will stay shut, which will not dump a load of muck in to the engine and risk the turbos. I'm not totally up to date with it all as I have a different system on mine (TD6) but I have seen a lot of posts saying that the turbos and the EGR's have gone, but you don't see many where it's just the turbos.
2nd Mar 2016 1:58am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
The real problem seems to be crank case ventilation entering after the EGR inlet. Oil vapour combines with soot in the exhaust gas to make a gooey mess. I'll try to post a pics from the WSM.
2nd Mar 2016 2:34am |
Hi kp, thanks.
2nd Mar 2016 8:06am |
