![]() | Home > Maintenance & Mods (L322) > Towing Mirrors |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
I tow a boat that is 8.5 feet wide (102"), though clearly a different shape.
Milenco Aero 2. Work fine. I added a 3rd clamp to each one to help with stability. Stay away from the grand aeros as they're bigger than is practical. |
Probably where I went wrong - I had Grand Aeros |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
i use the suck it and see type with a convex one on the near side. Never fallen off but have a little safety strap on anyway, advantage is they adjust with the mirrors
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I have the large milenco mirrors for towing my large caravan. I have tried the stick mirrors but they slipped and occasionally fell off.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
I use a set of these, |
Not true ![]() In the UK, the law is complex & vague - you need to have an adequate view behind you - which is generally interpreted as you need to be able to see 20m back & 4m either side - so it's all about the angles & length of the trailer. You don't explicitly need extended mirrors. It's probably quite complicated maths, but fairly straight forward to test. In Europe it may well be different. |
Probably illegal now ![]() I would guess that you can't buy anything which would typically be more than 200mm wider than the car just to be on the safe side. 250mm for post 2007 cars ![]() |
Trantorman Member Since: 13 Oct 2012 Location: aberdeen Posts: 161 ![]() ![]() ![]() |
All Many Thanks
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Not true!
It's never been the law - just an interpretation - probably true for 99% of cars with caravans given the dimensions ,but the law is just that you need adequate visibility.
This may assist.
Still not entirely accurate - it's the width of the mirror, not the rear of the car that matters, but close enough I suppose.
