Home > Maintenance & Mods (L322) > L322 door electrics not working |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
you've probably reconnected the plug wrongly or not fully seated them, i've done this myself ....i'd whip the card off and have a look.. ... - .- -.
29th Feb 2016 3:42pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
+1 stan, many threads about this, I had to do mine at least three times.
29th Feb 2016 4:07pm |
nubbin Member Since: 23 Jan 2012 Location: Sheffield Posts: 231 |
Thanks guys I'll have another go - I did disconnect and then reconnect once but in a bit of a rush as I was needing to get back to work. I'll have another go when I have an hour to spare. I did check out a few threads from various forums, and every answer was different! BeCM faulty, flat battery, frayed wires, faulty door connector, corrosion etc. etc. etc. That's why I thought I'd post here to try and get a sensible consensus |
29th Feb 2016 5:07pm |
Hi nubbin, you don't have to unplug all the electrical connectors.
29th Feb 2016 6:33pm |
Thanks for the tip - this is the second time I've had to replace the cable, the car is starting to feel it's age - I'm interested in getting an L405 new version RR, but even second hand they're still north of £50k, and as a tight Yorkshireman, I don't like dropping that kind of cash and watching depreciation eat my hard-earned! |
29th Feb 2016 11:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Mw neither |
29th Feb 2016 11:36pm |
