Home > Maintenance & Mods (L322) > 6 hp gearbox oil change
lawsey
England 2015 Range Rover Vogue SE SDV8 Corris Grey
Gearbox oil change
MY 07 .Can I drop my gearbox sump pan off without having to take any other bits off, checked on Wiki and they all appear to refer to the 5 HP BOX and not the 6HP as fitted to mine.
I will be fitting LR original parts as replacements and I remember reading somewhere problems with the filter tube. Needing extra clearance when removing and refitting..??
Mis posted in the 405 section....Ooops
Post #374402 26th Feb 2016 8:35pm
In that case you are looking at the wrong Rave... PM me your email address and I'll send you a link to the 3000+ page one for your FF Pete
Post #374427 26th Feb 2016 9:41pm
proser
Halyards - do you mind if I PM you fro the same ?? Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #374439 26th Feb 2016 10:11pm
Feel free.... Pete
Post #374440 26th Feb 2016 10:13pm
2006-2009 WM here,
https://drive.google.com/drive/folders/0By...VNfUHlXRUE ... - .- -.
Post #374442 26th Feb 2016 10:17pm
Cheers Stan... ignore my PM.... Thumbs Up Pete
Post #374444 26th Feb 2016 10:29pm
sako243
Yes you can. I'm mid change on mine (long story and even longer oil change).
I made sure I could undo the filler cap (do not, as Pete and I have both done, undo it completely with the engine off... Hilarity will ensue for any passers by).
Then made sure I could undo each bolt just a little on the tray. Everything torqued back up and took the dog for a drive then a walk then a drive to warm it up. Undo drain plug (suggest using a big funnel to help direct the gushing oil) and drain. Take off sump (I left some bolts in front and back to hold it in place until all 21 were out), watch for any extra oil left in the pan. I gave the rim a clean from muck (on box) and then fitted new one. ZF have a 3 page flow chart / guide in PDF form if you Google for it. Very useful and pretty much idiot proof. Ed
Post #374449 26th Feb 2016 10:44pm
rangie47
and don't forget to monitor transmission temperature when filling 2007 tdv8 se ,stornaway grey
Post #374451 26th Feb 2016 10:53pm
