Home > Technical (L322) > went in for oil change, came back out with AIR SUSP INACTIVE |
Ohwhatalad Member Since: 27 Jun 2015 Location: Cambridgeshire, South East Posts: 191 |
hi thanks for the help yes the car all working fine as far as i can tell it just bongs when i get in and out and cant adjust height!
23rd Feb 2016 8:36pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
If a height sensor was broken it wouldn't sit level and if an ABS sensor was out you would have a bunch of lights on the dash on from ABS to HDC to EBD...etc
23rd Feb 2016 8:49pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If they had it on a ramp with the wheels dangling down it can move the height sensors into a dirty part of their track and cause all sorts of problems.
23rd Feb 2016 10:17pm |
i had that, i didnt realise till i saw the tyre marks on my drive,
23rd Feb 2016 10:23pm |
Mine would jam the breaks on and then go into fault mode and deactivate everything.
23rd Feb 2016 10:57pm |
A height sensor passing through a "dirty" area would be an "at the time" fault, as soon as it moved back it would not show a fault any more... The sensors are just a very cheap but reliable Hall effect sensor that is totally sealed, they don't get dirty inside...
23rd Feb 2016 11:39pm |
The theory is they drag dirt back into the used part and as you say mine cleared after a while but as always decent RR diagnostics is the key I have found |
23rd Feb 2016 11:45pm |
is the allcomms from RSW a download and if so can i buy a generic usb obd2 socket reader and use it with their software?
24th Feb 2016 11:15am |
Phone Dan and he'll send you an IID tool next day... no great rush with yours, if the suspension is still at normal height... Pete
24th Feb 2016 4:28pm |
Have pm'd him! just waiting for a reply so then ill phone and order one
24th Feb 2016 4:30pm |
dan only has BT iid now |
24th Feb 2016 4:58pm |
if you can find a genuine one in the uk you can use their software, (or find somebody who has one as they are not locked to a vehicle), i believe but you would need to contact them to check, there were some crap copies floating around ebay that won't work. if not it's a case of ordering from the states which will take 2 -3 weeks at a guess but well worth the wait in my opinion. i am a bit out of touch with what else is on the market but i do know the allcomss is brilliant and although i have a faultmate extreme i still use the allcomms more often |
24th Feb 2016 10:43pm |
Thanks for the advice, i think as my car looks poo sitting so low i need something ASAP, i have found standard IID tool on ebay next day delivery for just under £300 so i think ill invest in that, just to get the code read and fault cleared to see if that does the trick.
24th Feb 2016 10:48pm |
I would gladly help out with the allcomms but the faultmate is vin locked with a €50 each way transfer fee.
24th Feb 2016 11:40pm |
