Home > Maintenance & Mods (L322) > BMW M62 4.4 engine on petrol and LPG Coolant pressue problem |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Hi,
25th Nov 2015 7:07pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Couple of points
25th Nov 2015 7:34pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
A good tip also DONT over fill the expansion bottle!
25th Nov 2015 10:55pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
This is the thread:
26th Nov 2015 12:25am |
Many thanks for the replies chaps.
26th Nov 2015 2:37pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I looked at fisha's thermostat and it's great if you want to keep it standard, but I could only find one that was three times the price of this which gives you the option to fit just about any temp stat you want, you do need to do a bit of metalwork to make it fit though....
26th Nov 2015 5:47pm |
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 |
Hi recently fitted the 80 c thermostat cap to my 4.4, still have the 200 coolant cap fitted , can anyone advise if they have had issues with the 140 cap. Been on other forums and owners seem to suggest problems with the140 cap, mainly leaks on the 4.4. Also any one have the part number, for this item. Also what does the 200 or 140 denote ? PSI, Llb sq inch, Kpa !. |
10th Dec 2015 4:07pm |
KPA, not PSI, if it was 200 PSI and it exploded I wouldnt want to be near it.
19th Feb 2016 4:01am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Mine had a 200kPa cap until a few days after I bought it and when it went in for a trans cooler replacement. The mechanic changed it to a 140kPa unit.
19th Feb 2016 5:21am |
With many reports of radiator, hose and expansion tank failures there are no reports of the 140Kpa caps lifting and releasing excess pressure.
19th Feb 2016 6:08am |
Not over sight, design choice to increase the running temp of the engine as a means to reduce emissions.... At the expense of spare capacity for overtemp/pressure. V8 or else ... |
19th Feb 2016 10:29am |
I have had what I would call high pressure operation with my cooling system.
23rd Feb 2016 9:50am |
With the temps you have out there you really should get one of these with an 80deg stat... they run so much nicer at the lower temp, it really is a win win situation... the engine and all the ancillaries will last much longer... Everything under your bonnet was fine when it was new but after a few years they deteriorate quickly when you get excessive heat under there...
23rd Feb 2016 12:27pm |
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 |
May i just add that I just discarded the thermostat altogether 4 years ago( just kept the housing ) , after a i blowed a top rad hose .
23rd Feb 2016 3:41pm |
