![]() | Home > Technical (L322) > Poor throttle response |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
JFR Member Since: 24 Aug 2012 Location: AMERSHAM Posts: 24 ![]() ![]() ![]() |
I only notice it when trying to manoeuvre slowly, with delicate throttle inputs. When pulling away during normal driving I use the throttle more aggressively and in those circumstances the problem does not arise. Current car: 2012 FFRR Autobiography TDV8.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Guessing here as not familiar with your late model, but have you ruled out a sticking brake calliper? Plenty of posts on here regarding those, other than that, perhaps the fly by wire throttle potentiometer could be the culprit. Ie the electric throttle 'cable' it's not a piece of metal rod/wire now it's a pedal sensor, and an electric actuator on the engine.
Has it got noticeably worse over time? Or just something you have noticed all of a sudden sir? |
It has been an occasional problem since I had the car from new, September 2012. It has never occurred when the main dealers have looked at the problem, and they have no constructive suggestions to make. Current car: 2012 FFRR Autobiography TDV8.
My own feeling is that it is the fly-by-wire, as the engine revs do not raise at all during the initial depression of the throttle pedal, only doing so when the car suddenly surges forward or backward depending which gear I am in. Current car: 2012 FFRR Autobiography TDV8.
So we are now saying that the engine isn't raising the revs by much until you have reached half throttle, as opposed to the car isn't moving until the engine is over 2000 rpm. 2 completely different things there.......
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 ![]() ![]() ![]() |
Interesting, I have a similar problem with mine - once in every hundred times I apply my boot to the throttle, the engine won't respond. Not turbo lag, just no increase in revs. I can adapt to this by double-tapping the pedal, or raise the revs slightly and hold on the brake, but not ideal if I were to lend the car to someone
Thank you, that confirms my suspicion that it is a fly by wire issue. Much obliged. Current car: 2012 FFRR Autobiography TDV8.
Just another thought |
Thanks, coincidentally I am at the dealers today, getting a new rear light cluster, damaged by the aforementioned problem!! I will pass on all the good advice received through the Forum. Many thanks. Current car: 2012 FFRR Autobiography TDV8.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
The throttle pedal is a very simple and reliable potentiometer that talks to the engine ECU and tells it how fast you want to go... the ECU uses some fussy logic... it learns how you drive, it does this by monitoring lots of things..... steering input and speed of turning the wheel, speed of pressing the accelerator or brake, vehicle speed, etc etc... it then decides if your having a "driving Miss Daisy" time or a "drive it like you stole it" time...
If L/R are using a linear pots, no wonder there are issues, I have yet to find an amp with sliding controls that doesn't crackle and pop after a few years ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Pete, surely it would only throw up a fault if the ECU sees the throttle moving and the engine does nothing.... But if it's the throttle pedal that's at fault, and the tracks are worn / damaged, the ECU will just see nothing and then FULL POWER |
