![]() | Home > Technical (L322) > Suspension fault or brake fault?? |
Take it back. Any problem with the ABS will fault the suspension.
Chasazim Member Since: 21 Jan 2015 Location: Perth Posts: 128 ![]() ![]() ![]() |
Thanks for the quick reply Joe90, the plot thickens, I did the battery reset and set off on a good long ride down the Freeway and round about the new housing estates, no bong, the wife wanted to have a look at the garden at our old house so I turned into the close, it was a tight corner,BONG. This leads me to think it is a steering related problem as I have noticed I only get the fault when I am turning into the garage, ie. going slow and turning sharp. I may be on the wrong track altogether so I will keep looking, |
Yep, steering angle sensor will also set everything off too |
Yep done that,it is strange because if I leave it for around 5 Min. Then it resets itself and all is active.Is there a sensor or something that I can check? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8398 ![]() ![]() ![]() |
Get someone with a code reader/scanner and read the live values coming from the steering angle sensor whilst you turn...
I just love my ff, she cured herself, all it took from me was to gently wash her and then tenderly rub her dry, hey presto, haven,t had a Bong since, done everything to try to bring it on but no good, |
