![]() | Home > Wheels & Tyres > What wheels are these ? |
Thought they were the 20" alloys that came with the Evoques ... |
Rrtdv8 Member Since: 09 Feb 2016 Location: Sussex Posts: 9 ![]() ![]() |
They can't be evoque wheels if they fit on a full fat |
I'm going to look at these wheels tomorrow
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
certainly were never a factory fitment from LR on the L322. they are as Mick said style 504 Evoque wheels, or copies there of, don't think the originals have Range Rover stamped on them.
rangie47 Member Since: 26 Feb 2015 Location: Malvern Posts: 296 ![]() ![]() ![]() |
the l494 has wheels that are slightly similar ,and in 20 inch
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3658 ![]() ![]() |
Having seen your other post I've just had a nose on the bay of fleas and they are Evoque 20” Style 6 Alloys, the Evoque uses a tapered (cone shaped) wheel nut, All the ffrr's and L405 use a flat washered wheel nut so they are totally different, and I'm not sure that the thread is the same, so on top of the extra ton they will have to carry, you will also need new wheel nuts that are tapered M14 x 1.5, if that is not the size that the Evoque uses |
Evoques are 5x108 PCD and FF’s are 5x120 so there is no chance the OP could accidentally fit a set of Evoque wheels to a FF anyhow Miggit |
Top picture is from a dealers website that is selling this FF |
Copies/fakes etc etc... ![]() |
