Home > Technical (L322) > Air suspension failure
Brooksy
England 2002 Range Rover Vogue Td6 Baltic Blue
My air suspension failed this morning and will not go up or down, I had it code red and got the code:
105-too much energy for regulation needed rear right
Am I right in thinking this would be the height sensor at fault ?
Post #371826 11th Feb 2016 5:18pm
Don't think so, that's not a fault I recognise as it's different from the IID faults in text, I would imagine it means the pump is using too much energy to raise the rear drivers corner, ie, it's pumping air in and the corner isn't rising. I suspect a failed airbag or a chaffed pipe to that corner...
Is the lockout light illuminated on the centre console?? Pete
Post #371853 11th Feb 2016 7:34pm
Brooksy
No the lock out button is not illuminated, just been looking through other posts and seems it could be the compressor at fault
Post #371866 11th Feb 2016 8:14pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
I had that code was a leaky bag on the front.
Post #371877 11th Feb 2016 8:40pm
Well it's sort of the compressor, the poor little thing can't keep up as a bag has a hole in....
If the compressor is no good the fault is that it's taking too long to fill the reservoir...
I stand by the first post, leaky bag or pipe... Pete
Post #371887 11th Feb 2016 9:40pm
