![]() | Home > Technical (L322) > Air suspension failure |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8398 ![]() ![]() ![]() |
Don't think so, that's not a fault I recognise as it's different from the IID faults in text, I would imagine it means the pump is using too much energy to raise the rear drivers corner, ie, it's pumping air in and the corner isn't rising. I suspect a failed airbag or a chaffed pipe to that corner...
Brooksy Member Since: 18 Sep 2015 Location: Caister-on-sea Posts: 23 ![]() ![]() ![]() |
No the lock out button is not illuminated, just been looking through other posts and seems it could be the compressor at fault |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
I had that code was a leaky bag on the front. |
Well it's sort of the compressor, the poor little thing can't keep up as a bag has a hole in....
