![]() | Home > General > Top specs year on year? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
In the latter ones you basically had
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I too struggled when trying to compare year for year and model for model so played safe and went for a 2012 Autobiography, being top of the range in standard specification. However, they too can have have optional extras so whilst in standard form they have more than the Westminster, for example, the first owner may have specified additional options.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
AB will be the top spec.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
I'm not sure Westminster's had the cooled seats. I've seen plenty without and just have blanking plates either side of the clock but the brochure I have says they should!.
not sure if this will show up ok...
Berty Member Since: 04 Jan 2016 Location: Leeds Posts: 73 ![]() ![]() ![]() |
The Westminster also comes with the harmon kardon 1200 watt stereo standard, even on the AB this was a option, so if you like your music bear that in mind, also what I noticed was even on the used approved Landrover site was the advertised specs were never correct,mostly higher spec not included in the features and just standard spec mentioned, always worth a phone call if something catches your eye |
The 322 runout WMs (2012) do have cooled seats, the earlier ones pre the last facelift not as standard. I wasn't sure about the stereo, but think Berty is right - it is certainly better than my 2004 Vogue was. Only Range Rovers since 1988 |
Not strictly correct sir... Ive not long bought an AB Black for a client and had four to choose from for sale in the UK and only two had all the nice bits! ![]() ![]() |
danp03 Member Since: 30 Nov 2015 Location: Newcastle Posts: 109 ![]() ![]() |
Hi Craig. What would you class as a poorly speced AB? |
One without all the options which were standard on the Vogue SE could be such a thing. I had one, a 2010 AB Supercharged. No Rear sear entertainment, no Hill start assist, no surround cameras, no adaptive cruise. A real strange spec to be honest and I only bought it for the colour.
As answered above |
I started looking at my12 wesminsters because I was told they were the top spec by a saleswomen at Stafford Landrover, on hearing the 1200 watt HD stereo that was a must for me, but I soon questioned why AB, s had adaptive cruise and headlights and a extra two cows in them,and wesminsters didn't ,on seeing the leather headlining on the AB things changed then for me I had to have a AB so looked long and hard through the used approved to find a AB with 1200 watt stereo, and I couldn't find one in 8 weeks of looking, I was then back on a wesminster hunt and by accident while looking at a wesminster stumbled on a AB but again no 1200 watt stereo (supposedly ) even the dealer said it hadn't one, I photographed the Chasis number to get the spec on vindecoderz and on checking it had the 1200 watt + reclining+ cooled rear seats not mentioned by the dealer, so by experience never believe the dealers I'd say checking the specs yourself before purchase may pay off, |
Hi. Is there a noticeable difference between the harmon kardon and HD? I have had an issue with my sub in the boot sounding like the pannels on the car are loose/vibrating. Dealer is changing the unit on Thursday so fingers crossed it improves things.
Also how do I know if I have high beam assist?
