Home > Maintenance & Mods (L322) > TD6 Ecotuning gearbox
Page 5 of 6 <123456>
chinkoa
United Kingdom 2004 Range Rover Vogue Td6 Java Black
No he couldn't, I agree. I will contact you Megawatt in 2/3 weeks to sort something out.
Post #263985 8th Jun 2014 11:56am
Mustard
Im interested in this also but not sure about the fitting,
do you have to chop into the wiring loom to fit this or is it plug and play ?
Anybody using the newest version available ?
Post #266175 19th Jun 2014 12:18am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
anyone still using the ecotuning? comments on the new version?
im thinking about to give it a try. long term experience would be helpful, thanks!
Post #326020 4th May 2015 10:03pm
jak480
Norway 2003 Range Rover Vogue Td6 Zambezi Silver
Hi I use ecotuning for over a year now here in Norway and for me it is working because the speeds here are mostly 80 km/hour this means that the gearbox is in a shifting range before the tuning it would kick down as soon as you touched the accelerator or encounter a small hill. The downside is that the motorvibrations are now more noticeable.
I do save some fuel but not very much.
Post #326039 5th May 2015 5:09am
Balki
Australia
ecotuning
i bought one a couple of months ago and installed it, very easy to do you only have to graft in one extra wire that comes out of the new ecu, i also had my gearbox full rebuilt and modified with better clutchs and a bigger torque convertor lock up clutch, im not sure about the ecu as yet, it does some strange shifting and doesnt seem to lock up consistently at the same speeds etc, i would like the tc to lock up at 50 kph but it doesnt till 70kph, can you update the software to the lastest version yourself or does it have to be sent back, and how can i checkk what version it is.
another thing im not sure if it afects it is my tacho doesnt work havent had a chance to see why.
the needle sits at 500rpm all the time but when i rev it to (guessing) 3000rpm it drop to zero
Post #326048 5th May 2015 8:33am
7spoke
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
Ecotuning gearbox ecu
I actually bought one over a year ago for the missus car...and never got around to fitting it! It was the modified one with the extra wire for engine speed. I had the gearbox oil and filter changed around the same time and all seemed well with the box. I'm not sure if I will ever fit it now ....I'm open to offers if anyone is interested....I'm in UK.
Post #326072 5th May 2015 11:32am
Tom Paine
Australia 2003 Range Rover HSE Td6 Bonatti Grey
Balki,
May I ask where you got yours, and how much in Oz dollars?
Post #337203 13th Jul 2015 12:35pm
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
spanner wrote:
Hi
1 silky smooth but changes alot quicker on road conditions eg hills
2 motorway and residential
3 I think the sport idication on the dash ios to say you are in eco mode because if you toggle the gear lever the sport indication dissapears and you are back to normal gearbox mode
4 ecu is next to engine ecu in box on left under bonnet easy swap 10mins
5 i dont tow
HI
sorry to bother you but do you know if these ecu are still available. if so where from. hows yours goin now Current. FFRR Vogue. TD6 Java black.
2009 Mini Cooper JCW in Black
Gone. 2006 Discovery 3
2008 Nissan Navarad40
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
2 x saphire cosworths
Various Mk1 & 2 rs Escorts (when i was young and mad)
Post #370939 6th Feb 2016 8:03pm
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
hello, the ecu upgrade is still done as i bought it just a couple of months ago. it a nice easy upgrade, heres the link.
http://www.ecotuning-automatic.de/
all you do is send payment via paypal and then send the ecu to his address on the site, a week later its returned, there is a wire to solder in when you refit now but its real easy and instructions are on the site to follow aswel.
Post #371186 8th Feb 2016 12:10am
thegamekeeper
what sort of difference has it made to gear changes. is it any better Current. FFRR Vogue. TD6 Java black.
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
Post #371364 9th Feb 2016 5:59am
arron
the gear changes are the same as before to be honest, the only difference is the torque converter locks up a lot earlier (35-40mph) and you can accelerate with out the engine reving alot a not seeming to do a lot, now the car picks up speed alongside the engine, the only thing i will say is sometimes it seems to hold the torque lock up / gear a bit too long when shutting down and can cause a judder, it is simple to drive around once you have experienced it a couple of times though, over all it is definitely worth the upgrade.
Post #372248 14th Feb 2016 1:03am
Ollie7195
England 2005 Range Rover Vogue Td6 Barolo Black
Hi everyone! been looking at doing this on my TD6, is the guy still going as I couldn't get the website link to work? I notice when I'm driving if I get above 35 mph and take my foot off the throttle the revs drop right down then if i accelerate gently they go up with the speed as though the t/c has locked is this standard for a normal TD6? (if i accelerate too much it drops down a gear and turns back into a rubber band) or is this "early" lock up when the t/c slips by 3% until it reaches above 50?
Thanks in advance!
Post #423343 17th Jan 2017 7:01pm
ahebron
New Zealand
I have been sorting out my boxes of Range Rover spares and came across the Ecotuning box still with instructions.
This is an early one I bought back in 2102.
If interested in buying please send me a PM.
Thanks
Adrian VW Amarok 2014 Highline auto
Post #432541 25th Mar 2017 12:44am
Nismotec
I dont suppose this is still available? An old thread I know... or where I can get my ecu modified?
Post #537699 17th Dec 2019 9:25am
Brian Considine
Maybe you should change your handle to "!Dr Emmit Brown" Rolling with laughter Rolling with laughter Rolling with laughter 2003 Range Rover Vogue TD6
Post #537703 17th Dec 2019 10:59am
