![]() | Home > Maintenance & Mods (L322) > Electric seat fault |
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
The drivers seat will no longer be operated in any direction. Not even the head rest. When pushing the switch the initial click is heard but no the seat does not move.
Anyone? -03V td6
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Hi,
I Keep thinking that as long as the fuses dont blow, it could be a fault code or something wrong with the controlboard. -03V td6
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That's what happens when you share your toy.... be selfish and keep the seat in one position..... yours ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Yes but if it is a clean break in the wiring, and, unlike ours, the cable cover had not split exposing the wiring which was shorting, the fuses will not blow. |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 357 ![]() ![]() ![]() |
Is there a 40amp fuse under
bump -03V td6
after changing the rear bumper we noticed that the wiering ther were broken. after that got changed the seat function normaly. dunno why -03V td6
