Home > Maintenance & Mods (L322) > Electric seat fault
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
Electric seat fault
The drivers seat will no longer be operated in any direction. Not even the head rest. When pushing the switch the initial click is heard but no the seat does not move.
The fuses is not blown and the passenger seat operates fine.
Have any off you experience with this fault. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #370217 3rd Feb 2016 10:08am
Norway
Anyone? -03V td6
Post #370724 5th Feb 2016 3:22pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Hi,
Had a similar problem although our fuses were blowing. The problem was that there was a break in the wiring loom under the seat. The back and forward motion of the seat had caused a couple of the wires to break internally and one was shorting out.
Could be a similar problem with yours.
Post #370726 5th Feb 2016 3:37pm
Norway
I Keep thinking that as long as the fuses dont blow, it could be a fault code or something wrong with the controlboard. -03V td6
Post #370844 6th Feb 2016 12:03pm
miggit
PaulTyrer wrote:
Hi,
That's what happens when you share your toy.... be selfish and keep the seat in one position..... yours Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #370856 6th Feb 2016 12:36pm
PaulTyrer
Yes but if it is a clean break in the wiring, and, unlike ours, the cable cover had not split exposing the wiring which was shorting, the fuses will not blow.
Post #370875 6th Feb 2016 2:08pm
Discotigger
I think the driver's seat is controlled by an ecu, does the Memory Functions, etc.
If you can get it on to a good diagnostics tool like the IID Tool, you can find out if there are any fault codes stored for the seat.
Post #370877 6th Feb 2016 2:17pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi Norway
Any Help ????
Good luck with the seat
Best wishes E777
Post #371136 7th Feb 2016 8:21pm
Norway
Is there a 40amp fuse under
the seat as in some LR. -03V td6
Post #372965 18th Feb 2016 4:44pm
Norway
bump -03V td6
Post #375669 4th Mar 2016 10:19am
Norway
after changing the rear bumper we noticed that the wiering ther were broken. after that got changed the seat function normaly. dunno why -03V td6
Post #397472 24th Jul 2016 8:35pm
