Home > Maintenance & Mods (L322) > 2010 grill on 2007 is it possible?
kbald
I have been having a search and can't find anything about modifying a 2010 grill to fit the 2007 cars so assume it's not possible.
I have seen that powerful do an L405 style one but was wondering if there's anyway to modify a 2010 AB style grill to fit an earlier car rather than doing a full facelift! These seem much more reasonably priced and there is miles more choice! Thanks in advance.
Post #370746 5th Feb 2016 4:06pm
if your an expert in fettling then it probably could be done , kinda.......but no is the answer.... ... - .- -.
Post #370747 5th Feb 2016 4:25pm
Mightymarcos
I don't think it is easy. When I bought my 2007MY car car last year the later style grill had been bodged on. I say bodged because the later grill is slightly taller compromising the shut lines above and below the grill. Also the cut outs for the headlights are at a different height which looked dreadful.
I challenged the Indy dealer I bought from who offered a second hand grill from another car. When I collected that car, the original grill was in a box labelled for the new style grill and obviously delivered only a few days before!
So I think I actually got the original grill for the car and the dealer had made an expensive mistake in trying to update the looks. I had a go at "fettling" to make the fit better but ruined it.
I think the aftermarket part is the only solution if you want a later look without a full facelift. Taking a rest from Land Rovers for a bit.......
Post #370770 5th Feb 2016 6:52pm
kbald
Thanks for the responses! I am probably the world's worst fettler so no chance of trying that!! Might consider spraying the grey surround on the supercharger grill but haven't seen that done on a Buckingham blue one so not sure if it would look better or worse! Question
Post #370781 5th Feb 2016 7:50pm
your car, so you can do what you want, obviously.
But, I tried all manner of grilles on my 2008, and non of them looked as good as the SC grill which was on it originally, had a black sprayed surround version, the aftermarket 405 version and an aftermarket SC grill as well as the standard vogue grill. The genuine LR SC grill is just a better finish than all of them, the centre is a smoked chrome paint which non of the aftermarket suppliers can match as far as i can tell and as said unless you are really good at bodging (which i have been know to be fairly proficient at over the years) adjusting the 2010 on grills to fit is tricky and involves cutting and plastic welding..... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #370784 5th Feb 2016 8:04pm
kbald
Thanks will have a look st a few pics to see if anything looks better! I'm surprised that there are no aftermarket 2010 autobiography style grills for the 2007 model and only the 405 ones! Would have thought they'd shift a few for people not doing a full facelift but want to freshen things up!
Post #370787 5th Feb 2016 8:47pm
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
the one on the right has the grill from powerful uk fitted
 Current. FFRR Vogue. TD6 Java black.
2009 Mini Cooper JCW in Black
Gone. 2006 Discovery 3
2008 Nissan Navarad40
Td5. Discovery
300 tdi Defender
200 tdi Defender
3 more Defenders
2 x saphire cosworths
Various Mk1 & 2 rs Escorts (when i was young and mad)
Post #370798 5th Feb 2016 10:19pm
