Home > Wheels & Tyres > 18" wheels with Brembo |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
As far as I know you don't have to flip the weight around on the FullFat I thought that was just on the Spert ( but I haven't done it so what do I know ) as for size the Comomotiv are the only 18" that will fit . 2008 MY Supercharged
24th Dec 2014 8:17am |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 |
thanks! |
24th Dec 2014 8:35am |
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 |
Assume this is 3.6TDV8 only - no 18's fit the 4.4TDV8 2017 Range Rover Vogue SE SDV8 (with e-diff)
30th Dec 2014 11:36am |
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 43 |
Hi, can anyone tell me if these 18" wheels will fit a 2008 TDV8 Vogue (for winter tyres)?
3rd May 2015 4:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
No sir they won't! Don't fit over your front brakes... You require at least 19" wheels (if using JLR) |
3rd May 2015 5:15pm |
Many thanks Craig.
3rd May 2015 5:36pm |
Yes sir, & too confuse matters more! From circa 2010 the Brembo's grew in size too sir
3rd May 2015 5:41pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 609 |
I've been in discussions with Barry at Compmotive. We've come to the conclusion that their wheels would fit the FF with no modification as they don't have the weights the semi skimmed do.
3rd May 2015 9:34pm |
Compomotives definitely fit sir as there are members on here that run them... Wasn't mentioned earlier as they are a lot more money than an old set of early 322 wheels the OP was asking about, Therefore probably irrelevant to this thread |
3rd May 2015 10:37pm |
Componitives will NOT fit cars with the 4.4TDV8 - I tried (friend has a 2008 TDV8 3.6 with these wheels); Front Brembos on the 2012 TDV8 are just too damn big!
18th May 2015 5:16am |
Kavandje Member Since: 25 Jan 2016 Location: Windhoek, Namibia Posts: 1 |
For what it's worth, I am using the rims in the image that Elandri posted on a 2007 TDV8. Only issue that I had was that I had to fit spacers. Couldn't find any decent narrow hub centric ones in my neck of the woods so finally put on 30 mm terra firma spacers. Rims fit fine and having 18 inch tires on are a huge improvement over the 20s for all of the gravel road driving that I do.
4th Feb 2016 10:06pm |
