Home > Wheels & Tyres > 18" wheels with Brembo
chex
Kenya
Does the flipping-the-caliper-weight around trick work only the comomotive alloys or also LR alloys?
Post #300710 24th Dec 2014 7:56am
As far as I know you don't have to flip the weight around on the FullFat I thought that was just on the Spert ( but I haven't done it so what do I know ) as for size the Comomotiv are the only 18" that will fit . 2008 MY Supercharged
Post #300712 24th Dec 2014 8:17am
chex
Kenya
thanks!
Post #300714 24th Dec 2014 8:35am
BlackPerth
Australia 2017 Range Rover Vogue SE SDV8 Mariana Black
Assume this is 3.6TDV8 only - no 18's fit the 4.4TDV8 2017 Range Rover Vogue SE SDV8 (with e-diff)
2012 Range Rover Vogue TDV8 Luxury (SOLD)
2010 Land Rover Discovery 4 3.0 TDV6 HSE Stornoway Grey (SOLD)
2006 Land Rover Discovery 3 SE 2.7TDV6 Black, G4 Challenge Copy (gone)
Post #301799 30th Dec 2014 11:36am
elandri
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
18" wheels on 2008 TDV8
Hi, can anyone tell me if these 18" wheels will fit a 2008 TDV8 Vogue (for winter tyres)?
Post #325790 3rd May 2015 4:57pm
No sir they won't! Don't fit over your front brakes... You require at least 19" wheels (if using JLR)
Post #325798 3rd May 2015 5:15pm
elandri
Many thanks Craig.
One sees many 18" wheels being sold as "L322". For the edification of those of us on a steep learning curve - do some models have Brembo calipers and others not?
John.
Post #325815 3rd May 2015 5:36pm
Yes sir, & too confuse matters more! From circa 2010 the Brembo's grew in size too sir Rolling Eyes
The latter models have their own 19" wheels but thats a whole different story...
So to answer your question Brembo 4 piston callipers were introduced with the SC model in late 2005 then adopted onto the 3.6 TDV8 model in late 2006 sir Thumbs Up
Post #325817 3rd May 2015 5:41pm
sako243
I've been in discussions with Barry at Compmotive. We've come to the conclusion that their wheels would fit the FF with no modification as they don't have the weights the semi skimmed do.
Only the Compmotive ones fit because they have a deeper dish and the spokes are further out the way than normal JLR wheels. Ed
Post #325876 3rd May 2015 9:34pm
Compomotives definitely fit sir as there are members on here that run them... Wasn't mentioned earlier as they are a lot more money than an old set of early 322 wheels the OP was asking about, Therefore probably irrelevant to this thread Thumbs Up
Post #325893 3rd May 2015 10:37pm
BlackPerth
Componitives will NOT fit cars with the 4.4TDV8 - I tried (friend has a 2008 TDV8 3.6 with these wheels); Front Brembos on the 2012 TDV8 are just too damn big!
cheers 2017 Range Rover Vogue SE SDV8 (with e-diff)
Post #328401 18th May 2015 5:16am
Kavandje
2007 Range Rover Vogue TDV8 Atacama Sand
Re: 18" wheels on 2008 TDV8
For what it's worth, I am using the rims in the image that Elandri posted on a 2007 TDV8. Only issue that I had was that I had to fit spacers. Couldn't find any decent narrow hub centric ones in my neck of the woods so finally put on 30 mm terra firma spacers. Rims fit fine and having 18 inch tires on are a huge improvement over the 20s for all of the gravel road driving that I do.
What I would like some help on is the threat of bearing failure. Having been warned about the extra loading factor causing this, I still have not managed to find any forum where this has happened to someone. In fact all that I have found so far is the opposite where people have not had any problems.
Has this happened to anyone here ?
Post #370602 4th Feb 2016 10:06pm
