![]() | Home > Technical (L322) > TD6 Torque converter, is there an H/D option? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Re heat, my thinking was based more on the nature of the job than specific overheating of the transmission. The lock-up clutch is perhaps more "active" than the clutch in a manual transmission, and without the ability to control the harshness, perhaps glazing could be an issue also. I imagine both clutches would give similar life because, even with lower strength, more friction means less slip. Just a few thoughts. |
Yes, but it is a very expensive "fix" when the box is actually doing what it should, other than squeaking between 30 and 50. To be honest I can afford to chance that the valve block may fix the problem, as I recon the problem is the excessive towing that I'm doing with the car. For the cost of the valve block I can replace the torque converter and do the ECO tune..... Don't forget that the Turbo is on it's last legs as well |
Yes, I know exactly what that's like. |
Well you said it. ![]()
I would think and early model (05/06) with a few miles on should be available for a bit less than a TDV8, and the TDV6 is a bit better on the reliability front. ![]() E.g. Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
The tdv6 is just as unreliable for towing. Look on their forum for Character and see what he's had replaced over the years and given up on and gone for a beaver tail merc now.
Peeps, I think that you are comparing my towing to your experiences, trust me you ain't towed nothing like these. I have pulled trailers with Landcruisers on them and Classic Rangies, and they aren't any near as heavy to tow. You can't compare them to a tin tent, I have a caravan, it's 28 feet long plus A frame, it weighs 1.8 tons, I can exceed the speed limit with out even thinking about it.
Not the cheapest, no, but a top example. I guess the major price differences are down to the engine and gearbox etc. - the 02-05 FF was just built that bit too soon to benefit so it's been left behind a bit.
It's less inclined to pop turbos than the TDV8 though - the comparison is often made on RRSport - and most importantly, you get the 6-speed box. Character - yes, he's replaced almost everything...but that was over 738k of towing before retiring! ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Yes it was but then I doubt his towing weights were often at the max 3500kg and shaped like a breeze block |
Nah, the tensioner issue is 100% preventable and even including them, engine failures are pretty rare. The turbo can be done body on, but even then, a skilled indy can have the body off in no time. The fuel belt on the 2.7 isn't timed so doesn't take long to change at all, and it's only every 105k/7 years. Anyway, we digress a bit. |
Yes, I guess it's not surprising that they push for full recons. Of course, a really dishonest place might give the "No, no, it's sealed for life, sir. It'll be fine" treatment...
3.0 you mean, presumably? Yes, I know a chap who can do it. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
I didn't ask as I don't have a Disco / Sport |
