![]() | Home > Technical (L322) > Parking sensors |
If the light is flashing, that means there is a fault sir and the reason you have no beeps... |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 187 ![]() ![]() ![]() |
Doh! Thought it was another indication I hadn't noticed before. ... |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
New sensors can be had for around £15 on the fleabay L322 2008 vogue
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 ![]() ![]() ![]() |
Sounds like a rear sensor as one of these not working throws the whole system out.
It's the rear ones only. Not done the walk round test yet but will check. Thanks guys. |
OK, senior moment. Found the wiki and that parking sensors are in the GTR bit but can find the parking section.as an aside I can't seem to open any topics in the folders. Help! |
