Home > Technical (L322) > Parking sensors
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Parking sensors
My parking sensors appear to work in that the dash light flashes in proximity to things, but the alarm doesn't sound. The rear camera works OK. Is there a separate fuse for the alarm? 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #369711 31st Jan 2016 11:35am
If the light is flashing, that means there is a fault sir and the reason you have no beeps...
Post #369766 31st Jan 2016 3:53pm
Triarii
Doh! Thought it was another indication I hadn't noticed before. ... Sad 17 MY Corris Grey 4.4 VAB
Post #369770 31st Jan 2016 4:20pm
If you look in the wiki above right... It will tell you how to check for the clicking when they work Thumbs Up
Post #369835 31st Jan 2016 11:49pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
New sensors can be had for around £15 on the fleabay L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #369836 1st Feb 2016 12:11am
Duracell777
Sounds like a rear sensor as one of these not working throws the whole system out.
I had a problem with one of my sensors at the rear not working (right outer). popped it out and discovered a corroded pin in the plug. After a bit of cleaning it all works perfectly. Thumbs Up
Post #369894 1st Feb 2016 1:02pm
Triarii
It's the rear ones only. Not done the walk round test yet but will check. Thanks guys. Thumbs Up 17 MY Corris Grey 4.4 VAB
Post #369964 1st Feb 2016 7:09pm
Triarii
OK, senior moment. Found the wiki and that parking sensors are in the GTR bit but can find the parking section.as an aside I can't seem to open any topics in the folders. Help! Embarassed 17 MY Corris Grey 4.4 VAB
Post #369966 1st Feb 2016 7:17pm
