Home > Technical (L322) > Fuel Pump Issues - Car won't start |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
check the fuel pump relay in the boot ,i had the same trouble swap it with the one at the side of it ,try that. |
31st Jan 2016 10:58am |
le25dse Member Since: 15 Jan 2012 Location: Oslo Posts: 78 |
The symptoms could also be related to some failing glow plugs. Have you had the codes read? ----------
31st Jan 2016 1:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
@ le25dse in Norway quite possibly but in Oz less likely
31st Jan 2016 5:00pm |
I'd put money on a leaking injector that bleeds off some pressure when parked or a high pressure pump giving early warning signs. You need a diagnostic to show injector correction/flow levels and fuel pressures within the system to compare to standard. I may still have readings in my gallery or in my blog/posts from what mine was like when it started to get bad and it did just get worse. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
31st Jan 2016 6:26pm |
