Home > General (L405) > Adaptive Headlamps
chris595959
2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
Adaptive Headlamps
My old 2010 Range Rover was fitted with adaptive headlamps
Have just purchased a new L405 and it has ordinary headlamps
Am I able to just swap and fit adaptive headlamps or can it only be done at build level
Post #338106 20th Jul 2015 10:13am
mzplcg
Not sure on the 405 but the 322 had more wires in the headlamp plugs and an ECU whcih takes readings from the steering angle sensor etc. Can be done (some of the D3 boys did it) but not plug & play.
Post #338109 20th Jul 2015 10:19am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
I bought my L405 from a dealer. I asked at the time and there was much sucking of teeth and harrumphing.
The answer I was given was "no". However, I suspect that perhaps was because they knew I'd want them to throw it into the deal and they didn't want to cut their margin any more.
I too would be interested if it wasn't a stupid price.
My guess is that you'd need new light units and someone with the right software to turn it all on.
Post #338110 20th Jul 2015 10:22am
mzplcg
Yes, they are expensive. I had an adaptive one replaced under warranty on my 07 VSE and that was over 700 quid for the part alone.
Post #338114 20th Jul 2015 10:45am
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I've got adaptive headlamps on mine. Better to spec them from the start as I imagine it would be expensive to retro-fit.
Post #338124 20th Jul 2015 12:50pm
JMDT
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Corris Grey
I specified adaptive lights with my new 405. A factory misbuild meant they were not fitted. JLR said they can't be retro fitted and suggested to build me a new one. Not sure why it should be so difficult but it must be as that's an expensive way to sort them out not being fitted...
Post #369576 30th Jan 2016 5:40pm
chris595959
I spoke to Landcover technical at some length
Yes the wiring is there but whats missing is different steering angle sensors and a control unit and a few other bits .
So you like me will have to order a new one . SUCKS
I really miss them Big Cry
Post #369586 30th Jan 2016 6:13pm
JMDT
Thanks. That would explain!
Post #369588 30th Jan 2016 6:17pm
L494defector
Would adaptives be standard on an AB L405?
Post #370139 2nd Feb 2016 10:05pm
JMDT
They are a £300 option. In my view should be standard on AB. Had them on my Volvo and really like them.
Post #370146 2nd Feb 2016 10:27pm
L494defector
ah i see ,
Thanks!
Post #370147 2nd Feb 2016 10:36pm
