![]() | Home > Maintenance & Mods (L322) > Safari Spot Lights - Any Photos? |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
spotlights are old hat Chris, go for a lightbar like seabass has,
CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146 ![]() ![]() |
That looks good weejock.
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 754 ![]() ![]() ![]() |
Think the safaris would look heavy Chris! These Warns look the dogs danglies!!!
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Nah. Lamps are still king; bigger the better when it comes to reflector efficiency and beam quality (not that there aren't good light bars still). Choose carefully if you opt for LED - there's a lot of junk about that isn't what it claims to be. LEDs won't match with the optics of a lamp designed for a filament bulb so I suggest you don't attempt a retrofit. ![]() Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Chris, the 322 spot lamps are a fortune from the stealers so maybe worth keeping an eye on fleabay? |
Trebaix Member Since: 17 Feb 2015 Location: Leics Posts: 24 ![]() ![]() |
This is what I fitted
Second attempt |
Blade74 Member Since: 01 May 2015 Location: Sydney Posts: 55 ![]() ![]() |
Does anyone know where you can buy spotlight/light at brackets to mount from behind the grill and not have to touch the plastic bumper.
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
Trebaix can you tell us how they are mounted to the bumper? 2017 Range Rover Vogue SE SDV8 (with e-diff)
DallasRob Member Since: 28 Dec 2017 Location: Dallas, Texas Posts: 10 ![]() ![]() ![]() |
Trebaix, what brand and model are your spot/driving lamps? They look great. |
^ They are genuine accessory spot lights from JLR sir |
vitola231 Member Since: 07 Jan 2016 Location: london Posts: 44 ![]() ![]() ![]() |
I built a small front bar for lights and protection, it mounts on factory screw holes. Used 11/4" steel pipe, built myself. Im happy with the results. I bent the pipe so it follows the curve of the bumper. |
