![]() | Home > Technical (L322) > EAS Conundrum, could it be the LCM at fault? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8396 ![]() ![]() ![]() |
Well that's lucky then.... |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Well, after a couple of weeks of rain / snow and other bad weather I've finally got the FF jacked up and checked the front air struts. Found a hole in the driver's side air spring bag, so I've ordered two new delphi air springs. Gonna try and get them fitted next weekend, so hopefully that will go a long way to sorting the problem.
What'd I Say |
Had my new Delphi Air Springs delivered Tuesday evening, so I'm going to try and get them fitted on Saturday...weather permitting.
Finally had to bite the bullet...weather's been |
Got the FF back yesterday, new air springs fitted so at least the front and rear of the FF is level, but the indy garage couldn't get the air suspension to raise or lower, still had the hold light lit up. They did a full diagnostics check using T4 Testbook, but nothing showed up. Not to worry I said to the mechanic, I've got a good idea what's up, it'll be the trailer module. Sure enough we disconnected the module and the light went out. Normal air suspension functions restored. WOOHOO!! |
Glad you got the EAS sorted
