Home > Technical (L322) > Centre rear seatbelt removal
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Due to some commercial VRT rate issues, I have to remove the rear centre seatbelt from my 10MY L322. I want to remove it intact and really would like to damage nothing. Does anyone have a guide or advice ? Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #369270 28th Jan 2016 11:22pm
exalin
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
You'll need to remove the rear seat and then take off the backrest cover to get to the seat belt retractor. Then take off the cushion cover from the base of the seat so you can remove the seat belt bolt that keeps the other end attached.
Post #369384 29th Jan 2016 4:31pm
Eric Cartman
got it removed anyway. I just have a slight issue now. When I try to put back the seat into the upright position its locked. If I push the metal plate that locks the seat in with a screwdriver it works then. Is it possible I have disconnected a spring or something that is responsible for this or is it just stiff ? Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #369777 31st Jan 2016 5:10pm
